Bifocals are a compromise, if you're going for best performance you'd need separate set for near (presbyopia at your age), and one set for far (myopia). It's a PITA to switch, but a good set for far will allow you to keep your distance.
One thing to have in mind is masks tend to direct part of the airflow upward, fogging your glasses. really hard to get the mask to cover around your nose.
