I got myself a CRTU (Thanks!), which has a few problems, one being a non-working TFT.
With a direct light against the screen, I can see the image is still working, it is just the backlighting that is not working. I assume that either the DC/AC Converter board is broken and/or the CFL.
This gives me hope and options for repair: fixing the Converter, replacing the CFL (not sure that would be easy, though) or trying to replace it altogether with LED stripes as described/linked somewhere in this forum.
The last chance would be simply replacing the front module or just the TFT with one extracted from another broken CRTU (with these parts intact, of course).
Anyway: I am stuck with the most stupid thing. I cannot extract the front module.
The service manual says the following for "Replacing the LCD and/or DC/AC Converter in the FRONT MODULE":
Opening the instrument and removing the FRONT MODULE
Switch off the instrument, pull the mains plug and unscrew the rear-panel feet.
Place the instrument onto the front carrying handles, push the tube upwards and take off.
Unscrew the four screws of the front handles at the instrument frame on both sides and take off the front handles.
Unscrew a countersunk screw (if present) at the front on the labeling panel next to the spinwheel and pull off the labeling panel towards the front.
Unscrew two countersunk screws in the front frame at the top and at the bottom as well as twocountersunk screws at the front above the AUX1/2 BNC connectors.
Unscrew a combi screw at the top of the module support for support of the PCMCIA INTERFACE.
After unscrewing the two countersunk screws at the top left instrument frame slightly lift the cover at the top of the instrument, slightly shift towards the right and lift off.
Slightly push the FRONT MODULE from the rear to the front using little pressure.
Note: Note the three ribbon cables for the PCMCIA INTERFACE that are still connected to the MOTHERBOARD1.
After sliding out the FRONT MODULE disconnect the three ribbon cables from the MOTHERBOARD1 connector.
Take the FRONT MODULE completely out of the CRTU Radio Unit.
This is where I don't know what to do and the manual doesn't provide any pictures:
Slightly push the FRONT MODULE from the rear to the front using little pressure.What cover???
In what position should I put the device???
What happens to me is that the front module seems to be attached to the input board on the upper right side. If I remove the screws holding the input board, then yes everything wants to slide out, but can't because of all the cables/wires (I did not do it, of course).
As I said, next to the PCMCIA module on the top upper right, both modules behave as if they are soldered against each other.
Is there any trick to it?
I can slide the front module out on the left side for about 15mm, but it won't move on the other side. And yes, I removed the screw holding in the PCMCIA module to the frame.
When I mentioned LEFT, RIGHT, UP, DOWN, I am referring from when you are facing the front side of the device, looking at the screen and buttons.
Any help would be appreciated. I don't want to push with too much force, to avoid breaking stuff.
Thanks,
Vitor
