I'm pretty sure it's an ES51920 from cyrustek, package and functions match.butthe datasheet is not public, and the IC is not public available ... only to lcr manufacturers ...try to ask cyrustek for a sample, explaining your problem ?good luck.
Wow, fantastic. Kudos to Cyrustek. Those chips are next to impossible to obtain, usually. You must have had a pretty good sob story.
Perseverance pays off once again. I think I would just have bought another one. I don't think Extech keeps parts for their OEM meters. If they are liable under the warranty, they would just give you a replacement.
wow I'm glad to see I helped in that way, and I'm glad to see such a customer support !I asked for samples once ago and they kindly refused to send any, and also no complete datasheet...and also lucky it was only that chip that was defective !be carefull with mains voltages next time !
