OK, I update some about repair job.
It's finished and working fine now.
In fact, not CPU board fault, it's failed in power supply.
+15V output is only +4V, and I found there is "pwr-fail"signal in module socket.(shows below)
Good module it output 5V, but this fail module output 0V.
I have no tracked where this signal goes into CPU systems, but I'm sure if this is low, it will halt whole CPU system from boot, maybe it's protect function, but it mistook me to check if CPU system was failed.
So it look like easy. Pull out power module, find +15V output zone, I found rectifier diode (FEP6DT) was shorted.
Purchased new one and replace it. Now 15V is normal. Whole 8711B run normally now.
