Author Topic: Tunable inductor for Moog Theremin  (Read 278 times)
Offline EugenioNTopic starter
« on: June 11, 2024, 09:31:26 pm »
I've got a Moog Theremin and I need to replace this tunable inductor because its ferrite core is cracked and can't be rotate:
2288167-0
It's a SLOT TEN5-10 from Coilcraft: https://www.coilcraft.com/getmedia/90724f9c-b8a9-4867-9507-a749f251f08c/slot10.pdf 47uH nominal (20uH-60uH range) with a fairly low Q=32.
Unfortunately I can't find it: it was quite uncommon at its heyday, discontinued by manufacturer and no longer available.
No one is selling nos parts on ebay (Europe).
Any suggestion?
Offline indeterminate
Re: Tunable inductor for Moog Theremin
« Reply #1 on: June 11, 2024, 10:12:18 pm »
Do not be to fussy
Usually sumthing that is ruffly the same will work , even if you just swap the slug out of one of the following you should be ok
https://au.mouser.com/c/passive-components/inductors-chokes-coils/variable-inductors/?inductance=450%20nH~~550%20nH&instock=y&rp=passive-components%2Finductors-chokes-coils%2Fvariable-inductors%7C~Inductance
« Reply #2 on: June 12, 2024, 04:48:29 pm »
Yea, I've been definitely to fussy  :-DD
Just bought a new tunable inductor like this one:
Removed the wire and cut away the base with pins, the ferrite core and its plastic sleeve fits perfectly inside the original tunable inductor.
The inductance range is close enough :-+
Great advice, thank you!
