Author Topic: LakeShore 330 temperature controller  (Read 2455 times)
Offline uweziTopic starter
    • GreenPhotons
« on: September 09, 2016, 06:58:50 am »
Does anyone here have a schematic diagram over a vintage LakeShore 330 temperature controller, or could otherwise tell me what component Q6 used to be?
I "fixed" the controller last week, where an OPA541 power opamp had blown out its magic smoke and it worked again for a couple of days, just to then burn up a TO-220 device on the same heatsink. Of the type number only the last two digits remain legible: ...15
Since its right leg was connected to the positive rail of the power opamp and since all other TO-220 parts inside are voltage regulators (plenty of them) I falsely assumed it must have been a 7815 - in the hindsight quite clear that it could not have been... :palm: - but I was proven wrong by a small explosion...  :-BROKE
The following users thanked this post: zrq
Re: LakeShore 330 temperature controller
« Reply #1 on: September 10, 2016, 07:49:39 pm »
7915, negative reg, not positive reg 7815 ?
Grab the datasheet for both, check the pinouts and typical application schematics.
Sometimes a pic of both sides of the PCB can help us......
Out of office and unavailable for a few days.
    • GreenPhotons
« Reply #2 on: September 12, 2016, 11:00:30 am »
I thought of the 7915 as well, but it does not make sense either at this position. Also as I saw later all 78xx and 79xx are labeled as Uxx on the board (as they should), while the burned part was Q6. I suppose it might have been a MOSFET like an "...N15" or "...P15"
    • GreenPhotons
« Reply #3 on: September 14, 2016, 03:51:36 pm »
Let me rephrase my question:
After a more detailed analysis of the traces and connections around the burned Q6:
Is/Was there a power NPN transistor around in the mid-1990s:
  • TO-220 package BCE
  • part number ending in 15
  • VCEmax > 60V
I am now quite sure that the transistor was part of a discrete voltage regulator with two zener diodes as references (1N5363 alone and 1N5363+1N5360 in series). The switching between the two ranges was done through a relay which also switched between two taps on the mains transformer.
Online Kleinstein
« Reply #4 on: September 14, 2016, 04:25:04 pm »
The BCE pinout it the normal one for TO220 transistors. So plenty of transistors to choose from.
For the BD series, there are some types with subtypes of -40 / -25 and -15. There might also be 2Nxx15 or 2SCxx15.
The following users thanked this post: uwezi
Offline little.tesla
« Reply #5 on: June 28, 2022, 06:53:34 pm »
sorry for resurrecting this thread.
Did maybe somebody in the meantime find a schematic of this device or did dump it's firmware?
Offline khach
« Reply #6 on: June 29, 2022, 07:45:51 pm »
Schematic diagramm
The following users thanked this post: lowimpedance, little.tesla, zrq
Offline zrq
« Reply #7 on: September 13, 2023, 01:45:36 pm »
I got hands on a Lakeshore 330 in the exactly same condition. Q6 was cut and removed by the previous owner and the OPA541 exploded. If anyone needs a memory dump, drop a message and maybe I can help.
