Author Topic: Equivalent replacement parts advice?  (Read 300 times)
Offline g.costanzaTopic starter
« on: September 13, 2023, 02:18:21 pm »
Is this the right place to make this request? I need a pair of parts to replace two BYV32E 200 PJA1921 C4 9115. Will any "BYV32E 200" work? I'm still learning. Can someone point me to an equivalent part? I'm in the US. Assuming they're in stock, which parts supplier is fastest (standard) shipping, and lowest cost? Thanks!
Offline u666sa
  • Country: ru
Re: Equivalent replacement parts advice?
« Reply #1 on: September 13, 2023, 02:40:16 pm »
I mean, if it's problem sourcing it. You should be able to replace it with two diodes.
But it doesn't look like a sourcing problem. More like a time problem.
Online DavidAlfa
« Reply #2 on: September 13, 2023, 02:46:28 pm »
Yes, any any "BYV32E 200"  will work.
