Author Topic: What blew up?  (Read 1490 times)
Offline iocowboyTopic starter
What blew up?
« on: March 11, 2018, 09:36:27 pm »
A friend posted a picture on FB earlier asking what component broke on his DC power supply. The symbol has me thinking resistor but the leads look too long and have me confused. Thought I would bring it to you all and see what you thought.
Aditional shots...
Offline jheatac
Re: What blew up?
« Reply #1 on: March 11, 2018, 09:38:49 pm »
Aditional shots...
Varister?
Sent from my SM-G920V using Tapatalk
Offline madires
  • A qualified hobbyist ;)
Re: What blew up?
« Reply #2 on: March 11, 2018, 09:47:01 pm »
Possibly an NTC to limit the inrush current. It would be in series with the fuse. A varistor (MOV) would be between L and N to absorb over voltage peaks.
« Last Edit: March 12, 2018, 09:49:28 am by madires »
Offline ArthurDent
Re: What blew up?
« Reply #3 on: March 11, 2018, 10:00:34 pm »
As mentioned, a non-linear resistor to limit inrush current. If you are replacing a NTC make sure you check the other parts around it to make sure you don't blow the new part as well.
Online Fraser
Re: What blew up?
« Reply #4 on: March 11, 2018, 10:26:04 pm »
The clue s was n the labelling...... RT1 ....... "Resistor Thermal 1"
As others have stated it is likely an NTC varistor.
Such parts often fail for a good reason.
Fraser
« Last Edit: March 11, 2018, 10:29:19 pm by Fraser »
