Author Topic: Electric fence with an unknnown component  (Read 1524 times)
Offline gg64Topic starter
« on: September 21, 2018, 11:57:29 am »
Hi there.
I am very new on the eeblog forum :).
So I got an electric fence (for cattle) that I am trying to repair.
The advertised specs are: 3Joules, 10kV.
Though I did not checked it, it was able to make quite a spark.
So it started to be really about weeks ago, it would not even show any sign
 of voltage onto the purposely designed voltmeter (basicaly I think this is just a bunch of
lamp with different resistance on them: I will call the ACME tester).
So after some test with it, I concluded it was the pulse coil that was deffective.
So I order a transformator (pulse transformator) core from ebay, received it.
I coiled it as at least like the former one (ratio of 10/1).
I tested with 10/1 nothing (onto the ACME tester) but it was able to make a small spark.
So I decided to go for 20/1, then I can see the lamps flashing onto the ACME tester.
After discussion with the user, we decided to ramp up to 30/1. Still working onto the ACME tester.
So I put some tips on the transformer (to make final installation).
I connected again the transformer with the load but I thought I plug correctly the transformer's primary (I DID NOT...)
I heard a tick sound.
So after some trouble shooting I concluded that the bt139-600 should be fried.
I bought 5 from ebay (along with some diodes (20x) em516 and a condensator 400vac 1µF).
1st try: Installed one the board, fried (not when connecting with the old tranformer the new one, with 30/1 ratio)
2nd try: Installed one the board, fried (not when connecting with the old tranformer the new one, with 10/1 ratio)
3nd try: Installed one the board, fried (not when connecting with the old tranformer the new one, with 1/1 ratio)
I measured 18kohm onto the old transformer, and the capacitor (in serial with the pulse tranformer) was reaching about 420v.
I decided that's enough. I should seek help. I am missing something.
Please note, according to the writing the fence should not go quicker than about 1Hz (he does: about 901ms period)
Here the schematics I reversed engineering except one components I can't figure what his specs are, is this a diode ?
(I got an idea but I don't want to skew people's opinion)
The "diode?" got a blue stripe right in the middle, I would like to know the value is supposed to be.
Here as join piece a QUCS schematic with the component named "whoami".
A photo with the unknown "diode?" circled in red (my cameras on my smartphone are dead, so no real nice close up photo yet, this is taken from a webcam)
Btw the simulation is not working for some reason (on QUCS) but it is basicaly a power side (left on the photo) and a pulse control side (right)
Also, I don't have osciloscope (i wish I had one....), no attenuation device, just multimeters able to go 600v and a capacitor meter.
QUESTION:
Does anyone can identify the compenent named "whoami" on the schematics (red circle on the photo) ?
I would be really thankful. :)
« Last Edit: January 18, 2019, 07:13:38 am by gg64 »
Re: Electric fence with an unknnown component
« Reply #1 on: September 21, 2018, 12:01:53 pm »
I didn't understand how to put several attachements as a first post, sorry. (missed the more attachments button)
Here are the rest.
Offline capt bullshot
« Reply #2 on: September 21, 2018, 12:04:03 pm »
Can't find a schematic within you post ...
As a wild guess from the photo and your description saying the circuit uses a Triac (the BT139), it might be a DIAC (triggering device). Especially if one end is connected to the Triac Gate.
The following users thanked this post: gg64
« Reply #3 on: September 21, 2018, 12:12:35 pm »
I forgot an attachements sorry, check the schematic as a second post. :)
I am trying to revive up an old smartphone, to take a clear close up photo. :)
Offline tpowell1830
  • Peacefully retired from industry, active in life
« Reply #4 on: September 21, 2018, 12:14:06 pm »
I would say it is a zener diode from the awful, out of focus, low light photo. No way to tell what value zener.
PEACE===>T
« Reply #5 on: September 21, 2018, 12:47:14 pm »
Here are some close up photos of the board.
https://imgur.com/a/H1LAujC
Online MK14
« Reply #6 on: September 21, 2018, 01:16:43 pm »
Here is one picture of a Diac. Someone else mentioned Diac in this thread as well.
Diacs often go with Triacs, as they make nice triggering devices.
« Last Edit: September 21, 2018, 01:24:22 pm by MK14 »
« Reply #7 on: September 21, 2018, 01:25:27 pm »
Oh, I never seen those. Thanks you, it seems to check out.
I know this is an english speaking forum but according to this website (in french, yes I am French deal with it  :) ):
https://www.astuces-pratiques.fr/electronique/le-diac-composant-electronique
It is common to use diac with a triac.
Here the same kind of information in english:
https://www.electronics-tutorials.ws/power/diac.html
So that will point me to check the power resistors I guess ? (not sure about it just yet....)
« Last Edit: January 18, 2019, 07:10:10 am by gg64 »
