Since you mention the firmware, I thought I'd ask. I have a DL24MP unit that gets stuck at the very start of the boot process, possibly during the self-test (not surewhat else it might be doing while showing that progress bar?) See the attached pic.
I wonder if any of you have any suggestions for where to go looking for faults.
The unit is in a 300W configuration, with the main board and one expansion. I have an encoder and an on/off button connected to the header above the LED flex cable. (I can remove all that for testing, but it involves a fair amount of disassembly and so I thought I'd ask first.)
