Hello everyone
A few months ago i bought a Tektronix TDS542A. I managed to get it relatively cheap (excepting import fees of course) because the seller advertised it as having an "Acquisition FAIL" message in the self test section.
To my surprise, once I turned on the scope, I found it worked perfectly, no faults at all. I still took it apart and gave the entire thing a good clean, it was full of dust after all. I took a good look around the main boards and saw no signs of corrosion or leaked caps, so i postponed the recapping operation because i wouldn't be using it too often anyway.
I left it sitting for a couple months and decided to turn it on again to get a measurement, to my surprise, it actually returned an "Acquisition FAIL" message, and after 2 minutes, something I haven't seen before in one of these scopes.
The screen started to flicker rapidly. No visible artifacts, just a rapid flicker accompanied by a vertically scanning bar and color shifting.
Video of the screen flicker in action:
https://youtu.be/smf7parbLRgI took a video of the screen and then shut it down. Time to replace all the electronlytics I guess. It took me almost two days but i replaced every single capacitor in both the power supply board and the display board.
I reassembled the scope and turned it back on, i thought the problem had been resolved, but after another 2 minutes, the flicker started again.
How should I proceed? I still haven't replaced the SMD capacitors on the processing and acquisition boards, as i thought the problem was on the display board itself.
Schematics and manuals:
https://1drv.ms/u/s!AnLlNyWb7uqghEhDepjOKs6jya15?e=wsOpiGThanks in advance.
