Author Topic: Keithley 230 Programmable Voltage Source Eprom dump anyone?  (Read 1187 times)
Offline MisterDiodesTopic starter
« on: September 28, 2017, 04:40:07 am »
I've acquired a Keithley 230 Voltage Source I'd like to repair - except one of its 2732 EPROMS has lost / losing it's marbles (eprom needs to be refreshed) - I can't get a consistent data dump.   The rest of the box is functional.
Does anyone have an Eprom dump set for the pair of 2732's in this box?  I saw a link at Xdevs but it leads to a "File not found" error, otherwise I'm not finding any sources for a bin or hex file set.
My chips are labeled 230-800-B6 and 230-801-B6.
Offline Jwalling
  • This is work?
Re: Keithley 230 Programmable Voltage Source Eprom dump anyone?
« Reply #1 on: September 28, 2017, 11:01:21 am »
Here's a set I saved off. They are version B12, though.
Recommend you start with a fresh set of 2732 chips, JIC.
« Last Edit: September 28, 2017, 11:03:07 am by Jwalling »
Jay
System error. Strike any user to continue.
The following users thanked this post: MisterDiodes, alm
« Reply #2 on: September 28, 2017, 01:30:58 pm »
Beautiful - Thanks!
