Hope for your help.
I have got problem "not spinning any brush" with Dyson V10 Animal.
Everything works fine, except brushes.
I found in internet a self-made schema of similar VC (not sure it fully correct). I also got V17 from a friend of mine for testing.
What I have done before this topic:
With an oscilloscope I checked what was going on when V10/V17 starts without connected brush.
And I got a same graph pattern on both VCs.
On good V17 pcb starts PWM output voltage on terminals (16 volts).
On broken V10 with connected brush : tries to start for short amount of time and instantly stops (by graph on oscilloscope same as like it not connected)
And I swapped U24, and U13 (ICs on schema) from V17 to V10 . And this ICs is absolutely OK.
At this point I can assume that V10 can't see a connected accessory brush.
Unfortunately, lack of knowledge can't lead me to solution. I cant't understand how V10 get OK signal when brush connected.
Hope that somebody helps me find a solution.
Regards, Andy
