Author Topic: Can anyone identify these SMD semiconductors?  (Read 464 times)
Offline BargainhunterTopic starter
« on: June 30, 2024, 01:24:26 am »
I need help looking for replacements for these SMD semiconductors.  I will post photos.  The board is from a Pioneer SX-S30 receiver and is a SMPS.
The first semiconductor is Q904 and is marked AZ43W.  Second is D905 and is marked L68.  Last is D906 and has the markings of two diamonds side by side with the number 66 and below is marked CU1M.  I'd appreciate it if anyone can tell me what the replacements are.
Thank you very much.
Offline fzabkar
Re: Can anyone identify these SMD semiconductors?
« Reply #1 on: June 30, 2024, 01:48:39 am »
AZ+xxW = INA5001AP1
https://www.idc-com.co.jp/product/Search/Pdf/en/111/INA5001AP1/0/ (datasheet)
https://spares2repair.co.uk/sony-transistors-tr-ina5001ap1-t111-1w (photo)
I'm guessing that CU1M is an ultrafast 1kV 1A rectifier, but that's a purely intuitive guess.
« Last Edit: June 30, 2024, 02:36:35 am by fzabkar »
« Reply #2 on: July 06, 2024, 07:16:44 pm »
Thank you for your help.  CU1M is an ultrafast 1kV 1A rectifier,
It is reading open on my diode check multimeter.
I will order a replacement and let you know how it turns out.
