Author Topic: Tektronix Transformer color codes?  (Read 2449 times)
Offline Gip-GipTopic starter
« on: July 30, 2017, 07:34:32 pm »
I have a PN120-0730-00 that is disconnected from the power supply board. It says on the transformer that the color codes are in the manual but alas, nothing was found
I have everything I need to find the ratios, I'd just like to check with everyone else to make sure that's the route I'll have to take.
PS if anyone knows a good way to test transformers of this size I'd greatly appreciate it. Right now I'm just hooking up an AC-AC adapter to the primaries and reading the voltages
