Author Topic: Dumpster dive Siemens Sitop 6ep1 336-3ba00-8AA0  (Read 572 times)
Offline Fenix999Topic starter
  • Country: pt
« on: July 21, 2020, 12:15:53 pm »
Hi all,
My first time that I found something useful in a dumpster, I found a Siemens PSU sitop 6ep1 336-3ba00-8AA0,  a 24V 20A single phase power supply.
it was in the dumpster for a reason, it doesn't work, I took it apart and found a leaking capacitor, replaced it tried again and it doesn't work... not even a pip..
I don't have experience repairing this kind to stuff but if some one has a schematic of the psu so I can give a try.
Thanks,
Ricardo
Offline Haenk
Re: Dumpster dive Siemens Sitop 6ep1 336-3ba00-8AA0
« Reply #1 on: July 21, 2020, 03:23:31 pm »
Like with all SMPSU - dangerous high voltage inside, even if switched off. Like in "life-taking dangerous". You really should be knowing what you are doing when trying to repair this stuff.
  • Country: pt
« Reply #2 on: July 21, 2020, 03:43:22 pm »
Thanks for the warning.
that's why I don't want to be probing around without having anything.
Offline Per Hansson
« Reply #3 on: July 21, 2020, 05:48:11 pm »
If one capacitor was bad then it is very likely there are more, especially of the same model/series.
Caps works worse when cold, therefore heating a device can sometimes make it possible to start.
Indeed I have had an identical Sitop PSU (albeit 3-phase) with this behavior. (Unit was replaced with a new one).
Post some pictures of the unit and it is easier to give suggestions.
