I did the same with a knob on a Sony CD changer.
The rubber coating had changed into a super sticky black mess, much like bubble gum.
I soaked the plastic knob in alcohol (IPA), used some rubbing, and it came out beautiful, high gloss black, better than original.
It appears these rubber coatings are sprayed on like paint.
I don't like these coatings, prefer the plastic finish.
These coatings, being rubber, are going to fail long before the plastic part fails.
These coatings add production cost, and cause early part failure (sticky mess). It's a waste of time and poor design decision.
I worry about this because I have other items with these coatings on them.
![Scared :scared:](https://www.eevblog.com/forum/Smileys/default/scared.gif)
Any other similar stories out there?
Thanks,
Gary
