Hello, I have a DPO 3034 that is not turning on. When you first press the power button the lightable buttons turn light up but no screen, fan turns on. Looking at the debug data it gets to the DRAM section and stops, fan is still running.
U-Boot 2009.08 (Feb 02 2011 - 10:33:21) Tektronix, Inc. V1.08
CPU: AMCC PowerPC 440EP Rev. C at 333.333 MHz (PLB=133, OPB=66, EBC=66 MHz)
Bootstrap Option G - Boot ROM Location I2C (Addr 0x54)
Internal PCI arbiter enabled, PCI async ext clock used
32 kB I-Cache 32 kB D-Cache
Board: Tektronix Redondo/Metro AMCC 440EP Main Board
VCO: 666 MHz
CPU: 333 MHz
PLB: 133 MHz
OPB: 66 MHz
EPB: 66 MHz
Programming DIA...done
I2C: ready
DRAM: 128 MB
Might just need to send in for repair.
