Author Topic: Does anyone recognize this 11 pin relay socket?  (Read 1409 times)
Offline Anton4Topic starter
« on: August 31, 2017, 07:10:31 pm »
The broken relay was a TEC relay 1226 24VDC
Offline cvanc
Re: Does anyone recognize this 11 pin relay socket?
« Reply #1 on: August 31, 2017, 08:47:43 pm »
I was going to say it's like the old Potter & Brumfield KHP series, but it's not quite the same - your seems to be 3PDT and the KHPs are 4PDT.  Good luck with your search...
Offline kasone
« Reply #3 on: September 06, 2017, 07:27:16 am »
Attaching a picture of the relay that broke down (TEC 1226 735100), didn’t finds any similar so I started looking for the socket to find a relay that fits.
Is an unusual relay socket due to the coil connectors are not in line with the pins for the contact, the coil connectors is closer to the edge.
To temporarily get around the problem, cables are soldered from the old socket to a new relay.
