Another one landed on my bench today,
a Peavey Mixing Amplifier.
It is a mono amplifier, so I cannot compare channels.
It is fine at very low levels, but as soon as you turn it up a bit, the music makes a Crunching Sound (distorting).
The amp module is nice oldschool with transistors galore.
When it was playing music, i waved my hot air station over the board, and when a 22uF elect cap (in the 1st stage of the amp) heated up, the volume got louder (but still distorting).
I then scoped the speaker output. With No input signal, the output is a smooth - 2.3vdc!
When I up the signal, then the waveform looks clean (at low level), but it is still centered around - 2.3v.
Any idea where to look (I seem to think that the -ve offset voltage is somehow key to figuring this out.)
P
I believe that this schematic is for the board (or a hightly similar one)
