Author Topic: Display 3478A  (Read 7987 times)
Offline hnjmklTopic starter
Display 3478A
« on: November 16, 2022, 09:32:39 am »
In an attempt to rotate the LCD (DSP1) of my 3478A it went KO, P / N 5061-1166. On YT someone managed to replace the 3457A LCD with different displays, even nixie, do you know a feasible project for this intervention? Is the 3478A's LCD different from the 3457A? In appearance they are identical but in the 3457A Service manual I did not find the P / N of the display.
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
Re: Display 3478A
« Reply #1 on: November 16, 2022, 11:58:28 am »
I think one of the most comprehensive discussions about replacing HP3478A displays is at the following thread:
https://www.eevblog.com/forum/projects/led-display-for-hp-3457a-multimeter-i-did-it-)
It starts with an LED replacement but there is also mention of using small OLED graphical displays.
(edit) found the other OLED thread. https://www.eevblog.com/forum/testgear/hp3548-hp3457-oled-display/
(edit) fixed URL
« Last Edit: November 16, 2022, 01:09:50 pm by rsjsouza »
Offline ledtester
Re: Display 3478A
« Reply #2 on: November 16, 2022, 12:26:17 pm »
https://www.eevblog.com/forum/projects/led-display-for-hp-3457a-multimeter-i-did-it-)/
The first link has a paren at the end which doesn't get included as part of the URL by the forum's editor.
Here's a working link:
https://www.eevblog.com/forum/projects/led-display-for-hp-3457a-multimeter-i-did-it-%29/
The following users thanked this post: rsjsouza
Offline M0HZH
    • QRPblog
Re: Display 3478A
« Reply #3 on: November 16, 2022, 01:59:58 pm »
I used a display from a cheap HP 3488A Switch/Control Unit to restore a HP 5385A Frequency Counter and did some reasearch at the time.
Many of the HP gear of the era use the same displays, there are 3 revisions "groups" where displays are compatible with eachother (so 3478A would work with a 6622A display) but no proof that they're compatible between groups (for example 3478A with 3488A display).
LCD PN: 5061-5212
HP 3478A
HP 6622A
HP 6630A/B
LCD PN: 5181-2813, 5063-2305 or 5083-3473
HP 3457A
HP 3468A
HP 3488A
HP 3852A
HP 5384A
HP 5385A
HP 5386A
HP 6624A
HP 6645A
HP 6674A
LCD PN: 5065-7075
unknown models, after 1995
I'd still get a cheap 3488A unit off eBay and try its display out on yours, not much to lose.
Some of my pics / comments from when I did the swap:
https://twitter.com/YO9IRF/status/1339663054053789696
« Last Edit: November 16, 2022, 02:06:12 pm by M0HZH »
Offline sagias
  • Country: gr
Re: Display 3478A
« Reply #4 on: March 09, 2024, 07:04:33 am »
Tested oled on 3478
Offline ZGoode
  • Grad student by day, equipment nerd also by day
Re: Display 3478A
« Reply #5 on: April 01, 2024, 05:27:53 pm »
Tested oled on 3478
Sagias,
That is awesome!  I'm trying to do something similar to what you have done.  Are you able to post any of the schematics/code for your work?
Offline Miti
Re: Display 3478A
« Reply #6 on: April 01, 2024, 07:13:46 pm »
Tested oled on 3478
Sagias,
The second link in the second post is what you need.
Fear does not stop death, it stops life.
Offline kawal
Re: Display 3478A
« Reply #7 on: August 26, 2024, 12:14:45 pm »
LCD PN: 5061-5212
HP 3478A
HP 6622A
HP 6630A/B
HP 3457A
HP 3468A
HP 3488A
HP 3852A
HP 5384A
HP 5385A
HP 5386A
HP 6624A
HP 6645A
HP 6674A
LCD PN: 5065-7075
I have a few 3852A that came with 5061-5212 displays  Rev A displays.  these have triangular  symbols on the bottom.
I did take a display from 3457A model 5181-2813 and placed it in the 3852A and it works.
I made a few OLED displays that work in the 3457A  but the same OLED display will not work in the 3852A. Very strange.
The following users thanked this post: coromonadalix
