Author Topic: Dirt, corrosion, flux and other random stuff cleaning  (Read 691 times)
Offline ianscottTopic starter
« on: October 20, 2020, 12:56:56 am »
Hey All
Just before I run out to buy an ultrasonic cleaner, what do you guys think is the best way of cleaning this attached board? Its a combination of dirt/dust,  corrosion, flux, oil and other random stuff the fan next to it has brought in.
Thanks!
Offline Haenk
Re: Dirt, corrosion, flux and other random stuff cleaning
« Reply #1 on: October 20, 2020, 08:52:47 am »
Very much depends on the components.
The flux stuff can be removed with IPA.
That battery corrosion can be removed with hot water and soap, maybe add a bit of vinegar. Wash with destilled water and put some laquer on the bare traces. *But* this very much depends on the parts on the other side and if it might leak through.
Offline m k
« Reply #2 on: October 20, 2020, 09:53:59 am »
Make a tight tuft from a kitchen paper tower.
Spray the area with todays freon and start brushing.
Finally clean shredded and dirty paper bits.
Advance-Aneng-Appa-AVO-Beckman-Danbridge-Data Tech-Fluke-General Radio-H. W. Sullivan-Heathkit-HP-Kaise-Kyoritsu-Leeds & Northrup-Mastech-REO-Simpson-Sinclair-Tektronix-Tokyo Rikosha-Topward-Triplett-Tritron-YFE
