Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Identify Resistor Type and Wattage
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Identify Resistor Type and Wattage (Read 132 times)
2X
Frequent Contributor
Country:
on:
October 09, 2024, 09:04:45 pm »
Hi, I have the below resistor on a working power supply where I measured it 120Kohm and I would like to replace it for preventing reasons (the colors on the image don't show very good but they match with the measured 120Kohm value). I believe it is a metal film resistor but what watt do you believe is?
The voltage difference across the resistor is 293V and the current 2.4mA P=V*I293V*0.0024A~0.7W. What watt do you suggest to choose... for my designs always I choose the rating wattage to be the double from the working watt?
I found the below:
CPF3120K00FKE14
https://eu.mouser.com/ProductDetail/Vishay-Dale/CPF3120K00FKE14?qs=AgiByKCM3cCJwbXOor8fIg%3D%3D
Carbon Film Vs Metal Film Resistors
https://components101.com/articles/carbon-film-vs-metal-film-resistors
Last Edit: October 09, 2024, 09:20:06 pm by 2X
Logged
fzabkar
Super Contributor
Country:
Re: Identify Resistor Type and Wattage
Reply #1 on:
Today
at 12:03:23 am »
Is this the startup resistor that powers the main PWM controller IC from the rectified mains? If so, then your replacement resistor is fine, although probably overkill for this application.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
