Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
TV HAIER 55DS2 does not turn on
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: TV HAIER 55DS2 does not turn on (Read 631 times)
ggc161169
Newbie
Country:
on:
July 09, 2021, 02:22:26 pm »
Hi, I have this
TV HAIER 55DS2
which does not turn on, it only marks the standby led on fixed, it does nothing when pressing the button or using the remote control. The voltages that are marked on the boards from what I see are correct. The led strips are discarded, since I was able to bypass them and turn them on with the PSU itself (in fact months ago it had problems with the backlight and I know that the TV turns on even by disconnecting the LEDs). I also discarded the button and the IR reception
. When disconnecting the T-CON it does exactly the same thing, nothing
. The main card is
CV59SH-K
and uses a
TSUMV9XUS
chip, the latter I changed it, being guided by someone who had a similar problem, but remains exactly the same without reacting. I believe and it is what I want to confirm that it is the bios chip (I don't know if they call it that) which is the
25Q32FVSIG
but it is clear that you have to have the firmware or software to flash it ... I have the interface to do that, but obviously I don't have the necessary file. I like to confirm someone the problem I would appreciate who has the supposed file, or failing that, some idea of what I could do. Thanks in advance
Last Edit: July 09, 2021, 02:24:16 pm by ggc161169
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
