A while ago (one year? Two?) I made the mistake of buying a cheap clamp meter with a 'tactile rubber' coating on the molded body. (I didn't know!) Now, the very first time I want to actually use the meter, I find the 'tactile rubber' has become sticky decaying gunk.
As this stupid stuff usually goes after some quite short period. I'm convinced any designer invoking 'tactile rubber' is either stupid, or using it as a deliberate planned obsolescence timed sabotage.
I was going to throw it out. But then thought I'd try 'skinning it alive' as an experiment. Maybe it could be recovered?
The decaying gunk is pretty well adhered to the underlying hard plastic case, but it _does_ peel off with enough force. I began with a scalpel, but experimented with other things and found the flat end of a small, thin stainless steel ruler worked best. The peeling blade edge has to be fairly narrow, or it's too much effort to push. It's also best to have a blunt-ish edge, to not scratch the underlying plastic too much. Something like a mini paint scraper. A spudger could work too. Whatever you use it needs to have something solid to grip, because a fairly high force is needed.
Also I was working in chemical gloves (avoiding getting the decayed rubber on my skin) so dexterity suffers.
After discovering it was feasible to remove the gunk, it became necessary to disassemble the meter so I could work on just the case pieces.
Then get down to it. Simultaneously tedious and satisfying. Die, stupid rubber, die!
Most of it removed. The selector wheel sure looks plain now without all the fancy bumps and color contrasts, but it should still work OK.
Had to quit for a while. Packed up to clear the desk.
Cleaning the gloves and tools. Everything is contaminated with 'sticky'! Wearing the gloves, clean with turps. Finally scrub the desk top.
Back to it. This stage involved alternately wiping with turps-soaked tissue, scrubbing with brass wire brush and brillo scourer, and chasing out a few remnants along seams with the screwdriver.
The final result. Apart from the plain wheel you'd hardly know anything was missing. Some scratching on the back where I started with the scalpel. Could buff it out, but I don't care. It works, and feels like any normal hard plastic thing now. Infinitely better than the sticky goo.
