Author Topic: How to repair a Motor Control Unit for a Whirlpool Washing Machine  (Read 15559 times)
Offline elecrtoguy
    • na
Re: How to repair a Motor Control Unit for a Whirlpool Washing Machine
« Reply #25 on: January 15, 2024, 08:42:36 pm »
My scenario pretty much the same. Those 3 green resistors. Anywhere to order them or a substitute maybe? Seems a lot I do find they want you to buy them by the thousands. I found one same specs, but it turned out to be some tiny one like maybe goes in a cell phone, watch, etc.. And that one was $10 I had to eat.. lol .. Thanks in advance..
Offline MarkF
« Reply #26 on: January 16, 2024, 01:43:11 am »
If you read above, @schnittker gave a Digikey part number:  Digikey VMP-R050-1.0-U, 50 mΩ, 3W resistor, $1.73 each
I also found a similar resistor at Mouser, but a lower power:  Mouser TLRP2H20WR050FTE, 50 mΩ, 2W resistor, $0.74 each
« Last Edit: January 16, 2024, 01:45:42 am by MarkF »
Offline Victor37
« Reply #27 on: March 13, 2024, 09:55:05 pm »
Did you find the correct chip? I have the same chip burned on my board. Thanks.
Offline DRJIMD
    • JIMD GROUP
Offline bjhiltbrand
« Reply #29 on: April 05, 2024, 01:09:52 am »
The main chip that often blows is Power Integrations LNK304GN. I replaced with LNK304GN-TL. Digikey 596-1022-1-ND
The three sense resistors that often blow are 0.05Ohms size 5025. I replaced with Isabellenhuette VMP-R050-1.0-U  Digikey 4423-VMP-R050-1.0-UCT-ND
The little resistor next to the switch is a size 3216 labeled 1R00 which is 1Ohm. I used Vishay CRCW12061R00FKEAHP Digikey 541-1.00UCT-ND
Thank you so much for the links to digikey. That made finding parts way easier. I was curious about the capacitor next to the sense resistors. I think mine has been damaged, but when I pulled it off my board and measured the capacitance, it measured .23nF. I can't find a 500uF cap anywhere. Do you happen to have the part number for that one, too? Thanks again.
