Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
Diameter of ChipQuik SMD removal alloy sticks?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Diameter of ChipQuik SMD removal alloy sticks? (Read 857 times)
badrequest400
Contributor
Country:
on:
November 02, 2023, 11:20:42 pm »
Could anyone with ChipQuik SMD removal alloy sticks (which come in a tube) tell me what the diameter of the sticks/wire is? Thanks!
Last Edit: November 03, 2023, 12:51:58 am by badrequest400
Logged
abeyer
Frequent Contributor
Country:
Re: Diameter of ChipQuik SMD removal alloy sticks?
Reply #1 on:
November 03, 2023, 02:41:32 am »
Ugh, my cheap calipers ate another battery, it appears...
So nothing exact, but I have a few sticks of it sitting here and they're noticeably thicker than the .8mm roll I have out on the bench, so maybe 1.2-1.5 range, I think.
Logged
badrequest400
badrequest400
Contributor
Country:
Reply #2 on:
November 03, 2023, 01:04:24 pm »
Thanks very much!
Incidentally, I recently discovered those calipers never switch off; even the expensive ones are the same; the on/off button only affects the LCD. Annoying because one cell would last 10 years otherwise. I've been meaning to modify mine to put a slide switch in there to really disconnect the power. There are posts online going back over 20 years regarding this issue!
Logged
Audiorepair
Country:
Reply #3 on:
November 03, 2023, 02:26:35 pm »
I have just some coiled wire that came in a kit, it is 1.2mm diameter.
Logged
badrequest400
jpanhalt
Super Contributor
Country:
Reply #4 on:
November 03, 2023, 02:44:32 pm »
I just measured mine. It read 0.055"(1.4mm). This is not my reason for positing, though.
1) My Mitutoyo brand digital caliper does seem to turn off as do a digital dial and linear caliper. The latter two are Mitutoyo 572 series with RS232-like synchronous output. All three turn off. When off, the battery in the dial gauge lasted several years. The caliper battery lasts far, far longer than the battery in cheap (like Harbor Freight) versions. It gets a lot more use and seems to last at least 3 years or more.
2) Chip-Quik does work, but be sure to clean it off before re-soldering. Or, are you planning to use it as a very low temperature solder? Reduced joint reliability has been demonstrated when lead-free solders are contaminated with leaded solder.
https://www.bomir.com/downloads/aim/Lead_Contamination_in_Lead-Free_Electronics_Assembly.pdf
Good mixing can help void it. I am not aware of similar stressed studies for mixtures of Chip-Quik and the other solder types.
Logged
badrequest400
Ian.M
Super Contributor
Reply #5 on:
November 03, 2023, 03:07:08 pm »
There are no conceivable circumstances where the use of Chipquik as a solder alloy would be a good idea, as its microstructure may be far far worse than a Pb contaminated lead-free alloy. Its strictly for desoldering.
See
https://forum.arduino.cc/t/what-is-chip-quik/412935
Logged
Veteran68
Country:
Reply #6 on:
November 03, 2023, 03:08:10 pm »
I don't have the ChipQuik brand, but I have some branded as SRA Fast Chip. Don't know if it's exactly the same or not. Both of my calipers (cheap HF brand and more-expensive-but-not-Mitutoyo-expensive) measure identically at 1.18mm.
Speaking of calipers, the HF calipers shown do have the power drain problem and will eat a battery sitting in the case. However the iGaging calipers do not suffer from the power off issue. If you're not looking to spend Mitutoyo money, I can highly recommend these.
Currently selling for $52 USD on Amazon US.
Last Edit: November 03, 2023, 03:09:42 pm by Veteran68
Logged
badrequest400
notsob
Country:
Reply #7 on:
November 04, 2023, 09:56:21 am »
For Chipquik SMD 8NL SMD REMOVAL ALLOY the sticks measure 1.17mm dia
Logged
badrequest400
fmashockie
Country:
Reply #8 on:
November 04, 2023, 04:53:15 pm »
Yea I would not recommend it as a low temp solder alloy. But I do use it a lot for chip removal. I prefer it to other methods (like heat gun) when you need to salvage the chip.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
