Author Topic: [Solved] Determine the value of the missing components  (Read 621 times)
Offline FatMexicanTopic starter
« on: May 14, 2024, 08:57:21 pm »
Any ideas on how to determine the value of the missing components values without removing the other components form a different section (the PCB has four identical sections that control motors.
FatMexican
« Last Edit: May 16, 2024, 06:59:02 pm by FatMexican »
Online wraper
  • Country: lv
Re: Determine the value of the missing components
« Reply #1 on: May 14, 2024, 09:05:01 pm »
It's obvious that PCB has exactly the same components mirrored on opposite sides (4 copies of the same circuit). Desolder and measure.
« Last Edit: May 14, 2024, 09:07:15 pm by wraper »
Offline MathWizard
« Reply #2 on: May 14, 2024, 09:08:26 pm »
Have you looked up any of the chip's? You might find some datasheet with example circuits, that are the same or similar to your's.
Where are the missing components, what happened ?
« Reply #3 on: May 14, 2024, 09:13:05 pm »
I Email the manufacturer waiting for the replay; hoping to avoid more disordering if possible.
Offline fzabkar
« Reply #4 on: May 14, 2024, 09:13:35 pm »
Could the EEW part be a dual MOSFET?
https://www.vishay.com/docs/64832/sia517dj.pdf
« Reply #5 on: May 14, 2024, 09:14:13 pm »
I was removing some connectors and was careless.
« Reply #6 on: May 14, 2024, 09:15:43 pm »
The missing components are capacitor and a resister.
Offline fzabkar
« Reply #7 on: May 14, 2024, 10:40:33 pm »
Yes, I know. I was thinking that tracing the circuit in that area could enlighten you as to the functions of these components. For example, gate resistors would be of the order of 100 ohms.
« Reply #8 on: May 14, 2024, 10:43:29 pm »
That is the website for the part
https://betafpv.com/products/f4-1s-5a-aio-brushless-flight-controller-elrs-2-4g
Thanks for all the help.
Online wraper
  • Country: lv
« Reply #9 on: May 14, 2024, 10:51:23 pm »
And what's the problem with desoldering 2 components when you need to solder the board anyway?
« Reply #10 on: May 14, 2024, 10:53:28 pm »
No problem I guess, just an academic exercise.
FatMexican
« Last Edit: May 14, 2024, 10:59:06 pm by FatMexican »
Re: [Solved] Determine the value of the missing components
« Reply #11 on: May 16, 2024, 07:00:30 pm »
The manufacturer send me the correct values.
« Last Edit: May 17, 2024, 12:37:21 am by FatMexican »
