For some reason, people wanted more information about what doesn't work to desolder large modules.
I have available to usual assortment of soldering/anti-soldering tools:
![](https://www.eevblog.com/forum/repair/desoldering-heavy-modules/?action=dlattach;attach=1295506;image)
In addition I have a variety of items the could be pressed into service if necessary:
![](https://www.eevblog.com/forum/repair/desoldering-heavy-modules/?action=dlattach;attach=1295512;image)
The module is attached to a pcb with SMD parts on both sides. The holes in the pcb have very little clearance. To desolder the module I tried:
- Soldering iron at 375 and 400c
- Air soldering station at 400c
- Adding new leaded solder
- Desoldering with Hakko 472B at a couple of different temperatures
- Solder wick
- Air soldering station and soldering iron at the same time
at that point I gave up trying to get it out in one piece and tried:
- Clipping the leads -- not enough clearance between the board and module
- Cutting the leads with a hack-saw blade. Worked but scratched the PCB and could only be used on 1 end of the module because of clearance
- Heating the pins in sequence while slowly prying up the module. Worked with the smaller pins but there is always the danger of damaging the PCB
In addition to the successful methods mentioned above, someone reported that they were able to remove one by turning up the heat on a desoldering tool and drilling out the end for the larger pins. I've order some low-melting point solder and plan to try preheating next time I'm forced to try to remove a heavy module.
Thanks for the good advice.
