Just the name would help.
I am looking for something but I do not know any names. I believe it is a small post used years ago to connect an alligator clip to it. Sorta has a T shape to it, the T at the top. I have spent hours on Aliexpress looking for it. Any ideas? Just the name would help.
Search Ali by the bolt size, that looks about 10mm, if you search aliexpress (for exampl) for 10mm binding post or M10 binding post you will find a few.
I'm looking for a source to buy large binding posts like the ones in the attached photos. I've tried searching the usual sources but haven't yet turned anything up.
