Author Topic: delta elektronika SM 3540 capacitor replacement  (Read 849 times)
Offline roggiiTopic starter
« on: September 11, 2022, 12:26:32 pm »
I was in the process of recapping my SM3540 since one capacitor had already failed.
It was there when I found a cap with 3 legs  and I'm not sure if I can just replace it with a modern counterpart. Two of the legs are connected to the minus rail, so its job is to increase current handling?  It is situated right on the output board.
Type: 674D 820µF 50V DC
I did not find anything to be special about this thing on the internet or am I missing something?
I would go ahead an replace it with a normal electrolytic cap 820µF/50V/105°C.
Maybe somebody can prove me wrong:)
Offline TheMG
Re: delta elektronika SM 3540 capacitor replacement
« Reply #1 on: September 11, 2022, 03:04:59 pm »
The extra pin is probably for added mechanical stability, since it's a physically large radial cap. No indications that this is a dual cap or anything special.
The following users thanked this post: roggii
« Reply #2 on: September 12, 2022, 06:51:11 pm »
Yeah you were right. Tore it apart for fun, the pin is just connected to ground.
Offline srb1954
  • Retired Electronics Design Engineer
« Reply #3 on: September 12, 2022, 10:12:54 pm »
Just check the PCB layout and make sure the two ground legs of the the capacitor aren't used to jumper between two different parts of the circuit.
