Author Topic: Identifying a mosfet/switching regulator? I()R 227H  (Read 2240 times)
Offline chaseadamTopic starter
« on: April 16, 2016, 02:38:01 pm »
I let the magic smoke out of a few packages on my Triton Charger. I believe this was due to a mistaken short which would have dumped ~20A through these (possibly at a -36v potential), I am am not sure. I would appreciate if anyone can point me in the direction of identifying the function and a datasheet.
The text I could see was I()R 227H
Offline sdk.61
  • Country: tr
Re: Identifying a mosfet/switching regulator? I()R 227H
« Reply #1 on: April 16, 2016, 03:43:25 pm »
Very good
Offline ruffy91
« Reply #2 on: April 16, 2016, 03:48:36 pm »
You are out of luck. It's an International Rectifier Mosfet in SO8. 227H is the datecode. The type is on the 2nd line.
« Reply #3 on: April 16, 2016, 05:16:54 pm »
The second line read either I6L0 or J6L0. Last two digits on the third line are 24. Looks like the third line is the ticket and that is toast unless someone can put the remaining information together to figure it out.
Offline siggi
« Reply #4 on: April 16, 2016, 07:45:44 pm »
Looks like you're not the first person to fry one of those. Looks like the same thing: www.rcgroups.com/forums/showthread.php?t=268510
Sent from my iPad using Tapatalk
Online wraper
  • Country: lv
« Reply #5 on: April 16, 2016, 08:08:42 pm »
IRF7424
« Reply #6 on: April 18, 2016, 01:49:33 am »
Thanks for the pointer! Didn't even occur to me to check the RC forums for similar repair attempts!
