Author Topic: Onkyo TX-NR708 with defective DSP chip D830K013BZKB3  (Read 2531 times)
Offline GeertTopic starter
« on: May 25, 2021, 02:41:57 pm »
I have an Onkyo TX-NR708 with a defective DSP chip D830K013BZKB3.
However these chips are known of it's premature failure and are swapped out with a newer revision D830K013DZKB3.
Because you can't buy the chips from TI because you need to own a Dolby-Digital licence I was wondering if there is a possebility to find them elswhere ?
All information is welcome !
Regards, Geert
Offline perieanuo
Re: Onkyo TX-NR708 with defective DSP chip D830K013BZKB3
« Reply #1 on: May 25, 2021, 03:48:34 pm »
some said they replaced D830K013DZKB3 from aliexpress/ebay with succcess, someone said D830K013DZKB4 worked but without audio stream capability.
imho the price+effort didn't justify, a replacement updated board is a better solution or just try some pioneer competition product
Offline dc101
« Reply #2 on: May 25, 2021, 07:44:01 pm »
Wouldn't the replacement DSP also need to be programmed? Or is the firmware for it stored somewhere else on the board?
« Reply #3 on: May 25, 2021, 08:51:59 pm »
You are probably right about justifying the price, the effort means nothing to me since it's a max 15min job swapping the chip.
I believe there are two different firmwares, one is on the DSP itself and the other on the board.
Regards, Geert
