Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Repair
DELL SE2416H
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DELL SE2416H (Read 1262 times)
Jane
Frequent Contributor
DELL SE2416H
on:
April 06, 2022, 05:53:23 pm »
Hello ,
monitor DELL SE2416H
What do you think the problem, like that at the video below, is caused by?
The monitor is only pluged in to mains ( no other input) and turned on.
Anyone experienced a such problem?
Logged
bob91343
Super Contributor
Country:
Re: DELL SE2416H
Reply #1 on:
April 07, 2022, 05:21:26 am »
Some kind of oscillation, maybe due to loose mounting screws on a circuit board.
Logged
Rasz
Super Contributor
Country:
Re: DELL SE2416H
Reply #2 on:
April 08, 2022, 08:44:52 am »
glass-tcon connecting ribbon or internal glass defect, very low probability of tcon and zero probability of scaler board/input defect
Logged
Jane
Re: DELL SE2416H
Reply #3 on:
April 12, 2022, 10:14:00 am »
The monitor works from the very beginning properly but only for one or two seconds only.
On T-CON there is an very hot (shorted?) IC marked as SM4047 .
Anyone know what kind of IC is that?
Thanks
Logged
Rasz
Super Contributor
Country:
Re: DELL SE2416H
Reply #4 on:
April 12, 2022, 11:14:59 am »
same defect
https://www.reddit.com/r/AskElectronics/comments/na3idv/trying_to_fix_my_monitor_asus_vc239h_need_help/
SM4047 is a DC converter for multiple supplies running the panel, they are also called Gamma correction buffers, VCOM generators etc.
example pinout for similar SM4053 part
https://www.pinterest.com/pin/471541023488781596/
what on the tcon board
Getting hot means something is shorted, most likely inside the panel or chip on flex buffers. Replacing this chip 99.9% wont fix the issue, replacing whole panel or one of the flexes by specialized shop will, but this is uneconomical outside of Asia (India-China).
There are also hackers (india/russia/china, its a true dark art) able to figure out which line is blown and bypassing it manually - this usually results in slightly darker picture with slighly visible gamma issues, but otherwise still working monitor. Example:
TLDR: buy a new monitor.
Last Edit: April 12, 2022, 11:20:43 am by Rasz
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Repair
DELL SE2416H
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
