Author Topic: Dell monitor PSU Ilpi-395 V.a 491a012f1400h03 - parts recognition  (Read 359 times)
Offline sdancer75Topic starter
  • Country: gr
Can someone take a detailed photo of the burned parts on the downside surface of this dell's monitor  PSU Ilpi-395 V.a 491a012f1400h03 ?
Offline DavidAlfa
Re: Dell monitor PSU Ilpi-395 V.a 491a012f1400h03 - parts recognition
« Reply #1 on: August 10, 2024, 01:14:25 pm »
New one for just 11 euro:
https://www.aliexpress.com/item/1005006291283437.html
They seem to be 2R2 resistors, bu when these burn is due a major failure, so check the transistors, diodes, etc.
« Last Edit: August 10, 2024, 01:21:52 pm by DavidAlfa »
  • Country: gr
« Reply #2 on: August 10, 2024, 02:13:54 pm »
I have already ordered one from AliExpress thanks.
Yes, I am pretty sure that all neighbor components have burned, I was just trying to recognize some of them until I receive the replaced one.
Offline MathWizard
« Reply #3 on: August 12, 2024, 06:11:34 am »
So it looks like a 3-terminal mosfet with some high voltage on it, and was it 2 source resistors in parallel that got toasted ? Do you know the supply voltage for the mosfet ? The gate drives on a lot of these types of things are all pretty generic, and the same.
Was it a main's powered Dell, so with some internal step-down type converter, or did it have a power pack ? Or was it a mosfet in a latter stage, running the backlight voltage rails ?
Oh nevermind I didn't look at David's post pic with the main's plug.
« Last Edit: August 12, 2024, 06:14:51 am by MathWizard »
