Author Topic: Replace Kzg 16v 470uf gpu capacitor  (Read 2025 times)
Offline FizZzyCapTopic starter
  • Country: no
« on: August 18, 2018, 07:08:39 pm »
Hi. Would like help in finding a similar capacitor that would replace one on a gpu (GeForce 7300LE 256MB pci-e ddr2) for a pc. The capacitor brand and specs are kzg 16v 470uf. The closest or might be the same capacitor i could find is https://www.ebay.com/itm/10pcs-470uF-16V-NCC-KZG-Super-Low-ESR-16V470uF-Motherboard-Capacitor-8x11-5mm-/173274684410 , but it read 1(7) 5K and gpu capacitor read 6(k) 8P. Im to novice to know if that have any meaning.
Thanks in advance for responces.
Offline wraper
  • Country: lv
Re: Replace Kzg 16v 470uf gpu capacitor
« Reply #1 on: August 18, 2018, 07:23:06 pm »
Don't buy Nippon Chemi-con KZG. Although it's a reputable manufacturer, KZG and KZJ series were bad. Also don't buy capacitors from ebay/China. Most from remotely reputable brand is counterfeit.
You should not bother abut date code or lot number. You should care about capacitance, voltage and ESR being not higher than original (from datasheet). http://www.nfjapan.com/datasheet/KZG.pdf
EDIT: you actually could buy KZG given they are from fresh stock (from reputable distribuitor), as problems should be already fixed by now.
« Last Edit: August 18, 2018, 07:27:49 pm by wraper »
  • Country: no
« Reply #2 on: August 26, 2018, 10:25:28 am »
Thank for responce.
I have a hard time finding a number associated with esr for the cap that needs replacement, finding only the terms "low esr or super low esr" ratings that are not very helpful when comparing to new caps. Do you know what that number might be?
Did find these https://eu.mouser.com/Passive-Components/Capacitors/Aluminum-Electrolytic-Capacitors/Aluminum-Electrolytic-Capacitors-Radial-Leaded/_/N-75hqw?P=1z0wrk5Z1yx4aw3Z1z0vn3uZ1z0vhz5Z1yzxe9eZ1z0wl9o that looks to be good based on range of low esr that mouser.com offers. Any opinion if one of those caps would be work would be to great help.
« Last Edit: August 26, 2018, 03:26:46 pm by FizZzyCap »
Offline Rasz
    • My random blog.
