Author Topic: PWM Controller Fuse? And Where to get a new one  (Read 906 times)
Offline VeramacorTopic starter
« on: May 23, 2018, 01:21:47 pm »
Hello all,
I bought a couple 100 AMP PWM controllers that I want to use for my two trolling motors.
They worked fine of course on land,  but when on the boat I did the most basic stupid thing in electronics - I reversed the polarity of the battery mains!
So lesson learned,  attached are pictures of what I believe is a burned brass fuse.
The trouble is,  I don't know what formal name of this type of fuse is called.  Is it a shunt serving as a fuse?   A few google searches turned up nothing because I know I'm not using the right terminology.
Can anyone point me in the right direction to possibly find replacements?  I don't just want to bridge the gap with just anything,  I would like to replace what was there.
Thanks for any help!
Jeff
Offline oventech
Re: PWM Controller Fuse? And Where to get a new one
« Reply #1 on: May 23, 2018, 10:43:40 pm »
One question is what PWM controller did you get? Pics of the whole controller would be useful. Might be able to identify the part that needs replaced.
