Just repaired a Roland keyboard, can't remember the number, given it back!
Problem was one note wouldn't sound. This keyboard is fairly old but the keys are velocity sensitive, so hot harder, louder noise.
With the keys removed pressing the floppy rubber bit down would give a note, but only loud.
I peeled the rubber bits back and gently swabbed underneath with an optical cotton bud, and lo and behold it worked fine.
The question is, how do these things work? Attached under the floppy rubber bit were two black discs, each about 2.5mm diameter. When the key is pressed these go down and touch two pairs of tracks on the PCB. I am guessing that these are magnets and the tracks are actually Hall sensors? Obviously the tiniest piece of something was keeping the magnets (?) away from the track so not detected.
See it all ran on a 64180 with a large custom chip, but not enough pins to give four per key.
