Author Topic: SMPS Mystery Controller IC  (Read 1470 times)
Offline lungchardTopic starter
  • Country: th
« on: September 27, 2017, 05:18:26 pm »
I am currently trying to repair a pool chlorinator controller that has a problem with the power supply.
I cannot identify the IC that is used in this unit. It is marked Q311  VJ34 but i can not find it anywhere. The Q may be a letter O or a zero, it is not clear.
It is low power, switches 380VDC and has integral switching device (no external mosfet).
I have attached a sketch of the circuit.
If anyone can offer suggestions as to what the device may be then i would be extremely grateful.
The equipment supplier refuses to help with this matter.
Thanks in advance for any ideas,
Richard
aka lungchard but that is a long story.
Offline wraper
  • Country: lv
Re: SMPS Mystery Controller IC
« Reply #1 on: September 27, 2017, 05:32:09 pm »
You'd better provide actual picture.
Offline wraper
  • Country: lv
« Reply #2 on: September 27, 2017, 05:34:24 pm »
Never mind, Fairchild FSQ311.
  • Country: th
« Reply #3 on: September 27, 2017, 05:45:06 pm »
Hello Wraper,
Many thanks for the reply.
So fast too, the ink was barely dry on the paper!
I will download the datasheet and continue with my repair.
Thanks again, much appreciated.
Richard.
Online xavier60
« Reply #4 on: September 27, 2017, 10:19:48 pm »
Fairchild is now part of ON semi. Wow!
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline wraper
  • Country: lv
« Reply #5 on: September 28, 2017, 07:21:43 am »
Yeah, there was a bloodbath in last 2 years. A lot of semiconductor companies got bought / merged.
The following users thanked this post: xavier60
