I'm seeing if I can repair a sticky select switch on a Hitachi V-1565 scope. Feels like there's some sort of grease or something inside that's dried up.
In order to get at the switch I need to take the frame apart, at least partially, which means getting the printed plastic control label card off to get at some screws behind it, which means pulling the knobs off.
They are on SUPER tight, and since the scope is otherwise in perfect working condition I'd like to not wreck the thing. Only two of the knobs (Volts/Div selectors) have setscrews. A few of the knobs have plastic tubes that reach further back and those slide right off. Most of them, though, feel like they're glued on.
Any advice for removing these things without damaging anything? Or maybe there's a less direct way to "heal" the gooey switch? I can't see the actual switch body.
Here's some photos!
http://www.smidgeindustriesltd.com/scope01.jpghttp://www.smidgeindustriesltd.com/scope02.jpg
