I am currently repairing a navigon 2100 GPS that would not boot. (lacked the equipment to properly test all of the components so I replaced as many passives as I could with replacements from other scrap electronics, and it somehow worked though I am still not sure what exactly failed. (the GPS has been in a car for the past 3-4 years including hot (35C+) summer days with the windows closed and in direct sunlight
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
I got it to boot properly and work normally, but the speaker is not very loud and kinda distorts. If I flex the speaker diaphragm the distortion stops, and after a while of doing it, the speaker gets slightly louder, but the diaphragm material is pretty hard (kinda been left in a hot car for a long time and the heat may have damaged the speaker)
I am able to find 26mm speakers, but none that have the screw mounts, and the mounting post for the speakers and the rubber lip, to hold them high enough to get close to the speaker grill, then some kind of lip or gasket material that is on the face of the speaker, presses directly against the speaker grill.
My main issue is finding a replacement speaker. The speakers that I have been finding, had the diaphragm extending out past the height of the rim, so gluing a piece of plastic to raise it high enough to press against the speaker grill will not work, and no one seems to sell speakers that have that gasket thing on the rim.
Is there anything that can possibly be done for the speaker?
speaker1 by
Hamster768, on Flickr
speaker2 by
gps1 by
gps2 by
