I have a Datron 1062 that does not go into cal mode. The unit itself seems to work fine as the volts (ac & dc) & ohms functions appear to work. It also has the current option but I have not tested that yet. When I turn the cal key in the rear, there is no cal symbol displayed on the front panel.
The key lock & the display seem to work as normal. When I turn the key in the rear, the 5V line from the key lock will toggle between hi and low but no cal displayed on the front panel. Also, when I run the self test, the display will illuminate the cal symbol as it goes through it's self test so it does not seem to be a display driver or display problem.
I'm guessing it's a problem on the digital board but I would like to see what others might think. Perhaps I am overlooking something simple or perhaps someone has seen this issue before.
It's not going to be a easy fix so I'm looking for the easy way out first.
