Author Topic: Tektronix 465B, 110V rail is 102V RMS with 40volt dips.  (Read 8438 times)
Offline kmc_resistorTopic starter
Re: Tektronix 465B, 110V rail is 102V RMS with 40volt dips.
« Reply #25 on: February 25, 2017, 10:36:55 pm »
(I hope this isn't a double-post, but I had an error when I last submitted this)
Stage 1 is complete. All the old caps have been removed and the board cleaned up.
This might help someone else doing this job, I found that I could use a Side Cutter tool
to clip two of the ground the leads off of each capacitor, making it only necessary to
desolder 2 leads to remove them. Did all the work with my Chem-Wik and 40W soldering iron.
Now to add in the ground lead connections and new caps...
« Reply #26 on: February 26, 2017, 03:44:10 am »
Thank you everyone for your pointers and suggestions.
Happy to report that the new caps are installed and everything is working. All of the power rails are now within spec and the 465B seems happy with the new hardware.
Shout out to Ron Childress for making that detailed PDF on how to replace these power supply caps back in 2008.
What a great first experience on the EEVBlog Forum.
all the best !
The following users thanked this post: RJFreeman
Offline james_s
« Reply #27 on: February 26, 2017, 04:58:20 am »
Good to hear it's back up and running. I'll make a mental note of this thread for when my own 465 eventually needs caps.
