Hi all,
I need some guidance in how to establish the fault in my lovely 1084ST monitor.
When I received it, the monitor did not power on nor was there any activity. The internal fuse had also not blown.
I therefore watched two YouTube videos of people repairing their 1084STs which had the same symptoms - no power. Both individuals replaced the TDA 4605 IC - a common point of failure apparently - and the 12K 2W resistor near the IC...I therefore decided to do the same.
Upon switching the monitor on, rather than being greeted with an illuminated green LED and active screen, I heard a distinct "pop" from the back where the fuse is. Now I am not certain the fuse has blown as I never checked, but it certainly seems that way.
So, after replacing the TDA and resistors, I had a brief moment of activity, but not the kind I wanted. My question is, what do I do next? The main board does not have that many components but I can't realistically replace them all.
I welcome your suggestions!
