Author Topic: CRT circuit Tektronix 465  (Read 4385 times)
Offline Grapsus
Re: CRT circuit Tektronix 465
« Reply #25 on: June 03, 2021, 11:23:15 pm »
Hello !
I think your HV multiplier box might be good. You are looking for some kind of intermittent issue around the tube. It might be a failing capacitor or even a cracked solder joint that changes with temperature.
I would wait for the scope to break again then carefully and systematically inspect everything around the tube:
 - filament current (pins 1 and 14)
 - isn't the Wehnelt disabling the beam (pin 2)
 - do we have acceleration voltage (mesh, pin 12)
 - is T1420 oscillating ?
 - if not measure everything on the primary until you debug it
I'm not a specialist on CRT but I think having current in the filament and -1700V on the mesh is enough to have a dot on the screen. If anything is getting in the way and deviating it, you can just disconnect it until you get the dot.
Good luck !
Offline vangheliTopic starter
  • Country: cy
« Reply #26 on: June 04, 2021, 10:13:14 pm »
The high voltage multiplier is not difficult to make from parts.
Thank you. I have read the method used by GRAPSUS in an old post .I appreciate more advice ,I am inexperienced on HV.
Today I was able to access the multiplier , the transformer and the diode CR1421 .
Is it possible that an high voltage ceramic capacitor is bad despite an almost perfect measurement of capacity?
Thanks
  • Country: cy
« Reply #27 on: June 04, 2021, 10:43:25 pm »
Hallo Grapsus ,
thank you for your help . I spent the day to disassemble the vertical board from the interface board :it was really a pain ,even following step by step the manual. I think that you already targeted the problem.At the moment I do not have an high voltage probe to check the voltages you said. But I can do the low voltages measurements. In my opinion the oscillator is working: the frequency is 50 khz , but I checked with an other oscilloscope a sinusoid of only 2 volt peak to peak on the collector of Q1418. Perhaps this is caused by a failing capacitor (C1421,C1422,C1423) on the side of the secondary of T1420 ,but their value measured with my DMM is perfect.The diode perhaps is the culprit , but at the moment I do not have the equipment to really test it.    By the way my diode is different from the one I saw on your pictures . Mine is anonymous , no marks for the cathode , no part number : perhaps somebody changed it.
Do you know what should be the correct   value of the resistance of the filament of the crt ?
I need time to do all the tests do debug the oscilloscope . I hope to profit of your knowledge.
Merci beaucoup!
Offline David Hess
  • DavidH
« Reply #28 on: June 05, 2021, 02:49:44 am »
It is very possible.  High voltage capacitors need to be tested at high voltage to reveal if they have failed.
Offline floobydust
« Reply #29 on: June 05, 2021, 03:28:40 am »
Another way to test the HV multiplier is using a signal generator and inject a 50kHz sine/square wave of at least 10-20Vpp (because multiplier HV diodes have high Vf). Discharge the CRT (using a resistor, a few in series to make say 1MEG) and then disconnect the HV wire from the CRT. You could leave it connected, the CRT anode then just acts as a capacitor.
Just to measure the multiplier's output, it should be around 6x and DC only coming out. I'm not sure- but the multiplier failures are likely a shorted diode inside.
Ceramic disk capacitors - if the dielectric is failing at voltage, there's corona hissing and a loud arc you will hear repeating over and over, but not in the potted module.
The other mystery HV diode CR1421 is "VG-12X; SILICON 12,000V 5mA" 250nsec 35mA and specs are Vf 22V to 30V, so it would read open circuit with a multimeter unless it shorted.
  • Country: cy
« Reply #30 on: November 10, 2021, 05:12:53 pm »
Hi everybody.
This is a very late post about the repair of my scope Tektronix 465 , due to the late finding of the required part.
Well , the failed part was the high voltage multiplier. I changed it , and now the scope is working perfectly.
I arrived late to the correct diagnosis , because I was convinced that ,in order to isolate the circuit from the high voltage multiplier , it was enough to disconnect the ground wire of the multiplier ( this was also the more easy and lazy way to proceed ,because it does not require the disassembly of the board). I do not know the failure modes of the high voltage multiplier , but I can affirm that the only way to avoid interference on the circuit from  a faulty multiplier , is to completely remove it. As soon I did the removal , the high voltage oscillator resumed normal operation , the beam came back (with reduced trace length due to the missing post-acceleration and everything seemed promising for a successful repair.
Thanks to  all the contributors who helped me.
