Author Topic: PHILIPS MCD388 AUX IN how to ?  (Read 1772 times)
Offline tiesto23Topic starter
  • Country: tn
« on: April 28, 2020, 10:01:40 pm »
hi
i have PHILIPS MCD388
it have wireless subwoofer
the dvd player i lost it
i want to to add aux in input to subwoofer and use it with jack cable not wirless
any sugg how to do it
this is schematic of amp board
THNX
« Last Edit: April 28, 2020, 10:03:35 pm by tiesto23 »
Offline Manul
  • Country: lt
Re: PHILIPS MCD388 AUX IN how to ?
« Reply #1 on: April 28, 2020, 10:41:09 pm »
Well, you can try something like that. If you have mono signal, you need only one resistor. You may need to change the value of resistors to get desired sensitivity.
The following users thanked this post: tiesto23
Offline Manul
  • Country: lt
« Reply #2 on: April 28, 2020, 10:47:49 pm »
And if you will never use it wireless, you can remove this resistor.
  • Country: tn
« Reply #3 on: April 28, 2020, 11:55:45 pm »
hi thnx for your help
i just make as you show me
but nothing in output no sound no distoration
what is the problem ??
Offline Manul
  • Country: lt
« Reply #4 on: April 29, 2020, 12:15:41 am »
There can be two things.
1. It is on standby (off)
Make sure, that LED is not on. I marked connection to this LED.
2. It is on mute (disabled output)
If there is voltage on resistor marked with arrow, it means it is on mute. Try to remove that resistor to disable mute.
« Last Edit: April 29, 2020, 12:30:39 am by Manul »
Offline Manul
  • Country: lt
« Reply #5 on: April 29, 2020, 12:29:47 am »
Sorry, I got it backwards, when LED is ON it means it is ON.
  • Country: tn
« Reply #6 on: April 29, 2020, 12:41:05 am »
the led is off
i try also remove resistor
nothing happen
Offline Manul
  • Country: lt
« Reply #7 on: April 29, 2020, 12:49:03 am »
Ok, do you have voltages from power supply +24V, +12V, -12V?
  • Country: tn
« Reply #8 on: April 29, 2020, 12:54:27 am »
yes i test it now
all ok +12 -12 +24
Online coromonadalix
« Reply #9 on: April 29, 2020, 01:08:02 am »
The TDA8947 has 2 modes of operation .... see table 5
https://www.nxp.com/docs/en/data-sheet/TDA8947J.pdf
Offline Manul
  • Country: lt
« Reply #10 on: April 29, 2020, 01:10:07 am »
Good. The problem is that STANDBY and MUTE is controlled by microprocessor and because you do not have active wireless connection, it turns off AMP.
But you should be able to force the AMP to work by removing these resistors.
  • Country: tn
« Reply #11 on: April 29, 2020, 01:17:37 am »
thnx very much now its work
but i notice sound its a bit low
any sugg how control sound ?
i mean increase\decrease
« Reply #12 on: April 29, 2020, 01:22:09 am »
something like this
see the photos,    instead of the fixed 10k ohms resistors  you add this circuit
  • Country: tn
« Reply #13 on: April 29, 2020, 01:26:32 am »
something like this
can you show me exactly how connect variable resistor on amp
i mean  in schematic
Offline Manul
  • Country: lt
« Reply #14 on: April 29, 2020, 01:35:36 am »
So you want volume control knob to be outside, like in this picture?
If you do not want this, then it can be done with lower resistors on AUX IN, like 4.7K, 2.2K, 1K... Lower resistors will increase sound.
« Last Edit: April 29, 2020, 01:37:59 am by Manul »
  • Country: tn
« Reply #15 on: April 29, 2020, 01:40:32 am »
yes it will be good to use volume control knob
how to conect it ?
« Reply #16 on: April 29, 2020, 01:46:15 am »
You have to do some small work on your side,  you have to understand how potentiometers works and how to connect them.
We have laid out the works for you ...  all your answers was in the post i have made with the 3 pictures ...
You have a beautiful tutorial here:
https://www.doeeet.com/content/eee-components/passives/basic-principles-of-potentiometers-variable-resistors/
  • Country: tn
« Reply #17 on: April 29, 2020, 01:58:57 am »
thank you very much ,, i dont understand exactly how its work im a beginner thats why i ask how to setup it in schematic that way i can understand  it very well
thanx
Offline Manul
  • Country: lt
« Reply #18 on: April 29, 2020, 02:02:22 am »
Well, something like that.
« Last Edit: April 29, 2020, 02:07:38 am by Manul »
  • Country: tn
« Reply #19 on: April 29, 2020, 02:09:54 am »
thank you very much for your help & good assistance
tommorow i will add this changment and tell you the result
thnx
#staySafe
