Hi there,
Do you have experience with this scope, is it your own? On some scopes you need to press the trace positioning wheel. in order to bring the trace to the center of the screen.
Then again it is also measuring a large negative value. If it is a general problem, It mail be a faulty supply rail or some reference voltage to the ADC. Take it apart!
Happy hunting,
Pascal.
