In model TDS500B/C/D has been successfully tested.
TDS500 and 700 series, in the same model, they have the same firmware and acquisition system, and similar processor board.
Only need to add and change some components, you can change TDS500 series to TDS700 series.
Before you upgrade, you should first install the color LCD monitor via the VGA out connector.(A similar project (Simmconn Labs) to this topic, he uses FPGA reads display memory, and "color" the data. This solution is too complicated and expensive.
![Broken! :-BROKE](https://www.eevblog.com/forum/Smileys/default/smiliey_scope_broke.gif)
TDS520B -> TDS724A
TDS540B -> TDS754A
TDS520C -> TDS724C
TDS540C -> TDS754C
TDS580C -> TDS784C
TDS520D -> TDS724D
TDS540D -> TDS754D
TDS580D -> TDS784D
For TDS500B series(All changes are on the processor board).
remove:R12(model ID) R151 & R152 & R153
replace:U251 74F04 to U250
install:U837 & U835 & U836 & U834 TC528257J-70 Video RAM
![](http://www.qsl.net/b/bi4lbk//images/uptek/VRAM500B.jpg)
![](http://www.qsl.net/b/bi4lbk//images/uptek/vram.jpg)
![](http://www.qsl.net/b/bi4lbk//images/uptek/banner500b.jpg)
![](http://www.qsl.net/b/bi4lbk//images/uptek/cset500b.jpg)
![](http://www.qsl.net/b/bi4lbk//images/uptek/hpage500b.jpg)
![](http://www.qsl.net/b/bi4lbk//images/uptek/fft500b.jpg)
For TDS500C/D series(All changes are on the processor board).
It has been a long time since I finished this work. I have forgotten which resistors I changed (for the model ID).
The following two pictures are used to compare their differences, please try it yourself.
![Face Palm :palm:](https://www.eevblog.com/forum/Smileys/default/facepalm.gif)
install:U834 & U835 & U836 & U837 TC528257J-70 or M548263-60J Video RAM
![](http://www.qsl.net/b/bi4lbk//images/500D/520Mres.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/784Mres.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/vrm500d.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/banner500d.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/cvbs500d.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/grnw500d.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/java500d.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/splash500d.jpg)
Soldering SOJ packages is a bit difficult, make sure they are soldered reliably. Otherwise there will be a vertical line or flashing display.
![](http://www.qsl.net/b/bi4lbk//images/500D/badvrm1.jpg)
![](http://www.qsl.net/b/bi4lbk//images/500D/badvrm2.jpg)
enjoy it.
![Cheesy :D](https://www.eevblog.com/forum/Smileys/default/cheesy.gif)
