Author Topic: Tektronix 2235 upgrades  (Read 2665 times)
Offline MrElectricTopic starter
« on: February 23, 2020, 08:09:14 pm »
I have purchased a Tektronix 2235, and am wondering about the 050-2242-03 upgrade. According to the Tektronix document, the upgrade is for Tek 2235 Serial numbers B010100 - B041675. However, all B* serial numbers are USA made scopes. My oscilloscope starts with a 2, (203790), which means it was made by Tektronix UK.
Will this upgrade be appropriate for my scope?
Re: Tektronix 2235 upgrades
« Reply #1 on: February 23, 2020, 10:19:03 pm »
Datasheet here: http://hakanh.com/dl/docs/kitinstructions/050-2242-03.pdf
I would not touch it unless it's broken. The 223x power supplies are a complete sod from end to end.  I have a thread here on one which decided to explode: https://www.eevblog.com/forum/testgear/tektronix-2235-repair-thread/ .
Offline george.b
  • Country: br
« Reply #2 on: February 24, 2020, 05:02:24 am »
And I would second that.
Offline TERRA Operative
  • Country: jp
  • Voider of warranties
    • Near Far Media Youtube
« Reply #3 on: February 24, 2020, 01:01:18 pm »
If you really want to get your hands dirty, I have the info for this upgrade in my crappy video on the restoration of my 2235.
Offline wizard69
« Reply #4 on: February 25, 2020, 02:43:47 am »
Thanks for the great video.   I have an old 2230 that I need to repair, when I get around to it, hopefully there are some similarities.   Unfortunately it is more of a not working variety so may require more work than you had here.
« Reply #5 on: March 01, 2020, 01:33:49 pm »
Thanks! I have now tested the oscilloscope more, and I think everything works, except for the intensity control for the B channel, which does not do anything. Turning the main intensity control seems to affect both channels.
