Author Topic: Component Identification - PJ1499 LZ  (Read 792 times)
Offline killingtimeTopic starter
« on: March 22, 2023, 10:24:01 pm »
Anyone know what this component is:
https://i.ibb.co/DprLPHY/Untitled.jpg
Can't find any info on the marking. It came from a switch mode supply and was connected across the supply rails just before the mosfet switch (it's not the rectifier diode after the mosfet - that was much bigger).
It was letting the magic smoke out. Guessing it's either a diode or tantalum cap. Measures 3 ohms in both directions. The PSU works fine without it.
One other thing. All the schottky diodes in a bridge rectifier config had a forward Vf of 0.2v and a reverse Vf of 0.7v (in circuit). They were all fine. Shouldn't they be open circuit in reverse?
Thanks.
Offline fzabkar
Re: Component Identification - PJ1499 LZ
« Reply #1 on: March 22, 2023, 10:59:53 pm »
I suspect it's a unidirectional TVS diode.
http://www.smdmark.com/en-US/search/code?id=lz
« Last Edit: March 22, 2023, 11:01:46 pm by fzabkar »
Offline Kim Christensen
« Reply #2 on: March 22, 2023, 11:28:30 pm »
That's the problem with measuring things in circuit. Other components are in series/parallel with them. Take those readings with a grain of salt.
« Reply #3 on: March 25, 2023, 12:34:37 pm »
Found a website that says it could be a schottky diode. Equiv: PJ942K MB510
https://www.yoycart.com/Product/551538695332/
Offline fzabkar
« Reply #4 on: March 25, 2023, 03:38:56 pm »
That's an MB510 diode:
https://www.panjit.com.tw/upload/datasheet/MB510-AU.pdf
"PJ" is Panjit International. "1499" must be some kind of date and batch code. "LZ" is the part ID.
PJSD24TS, Panjit, TVS diode, 120W, 24V, marking LZ, SOD-523:
https://www.panjit.com.tw/en/Product/downloadPDF/PJSD24TS
ttps://datasheet.lcsc.com/lcsc/1811021612_PANJIT-International-PJSD36TS-R1-00001_C304458.pdf
« Last Edit: March 25, 2023, 04:56:38 pm by fzabkar »
